Part Number For Xenon Headlights Ballast Needed!
Anglicomarine0326:
The Number of the Valeo Ballast is: LAD5G. .....This Ballast is for the Low Beam HID Bulb....and they cost something like $100.00.....a piece! .
The High Beam, which your Photo shows as (ON) is a Halogen Bulb that s set in a Reflector Type Light. That High Beam Bulb can be replaced with a short LED Bulb, The Light source on the LED should be the same distance from the Base of the Bulb as the Halogen Bulbs Light source. If you don't have the same distance here, the High Beam will scatter Sparks of Light all around the Beam Pattern. Check out "The Retrofit Store". They have a short Movie about this....
Be sure that you buy the replacement Bulbs of the HID's that have 6000 Color.....That is the Bright White Light you can get....the Wattage should be the highest you can find.
Billy Clyde @ Cinco Ranch
Anglicomarine0326:
https://www.ebay.com/itm/352520195574
