passenger door status
Has anyone seen the following:
My 2003 XK8 convert just started giving me a "passenger door open" warning, even though the door is clearly shut. If I run the window down, the message goes away. Run it all the way up, the message comes back after the window does the gap adjustment. I noticed that the gap adjustment action moves the window up, but then drops it slightly - that is when the message comes on. I have done the electronic window adjustment procedure with no improvement. I am guessing I will need to get into the door and make sure all the regulator adjuster bolts are tight and adjust if necessary. Thoughts?
Update: it's been dry in northern Kentucky for a while and the "passenger door open" message is gone for some time now - as suggested, moisture in a sensor must be the culprit. The car will soon be back in the garage since we've dispatched most of our moving boxes that ended up there. Also, the passenger door latch replacement project will start sometime soon.
Jon89
05-11-2012 02:54 PM
sidewinder
26
10-16-2011 09:50 AM
