Passenger Front Window Gremlins
Aloha Fellow XK8ers,
Having an issue with my passenger's side window. It worked intermittently and now , not so much. When I press either window switch (drivers, passengers) I only get a clicking sound both in the "up or down" direction. When locking the car, the door locks will cycle open/close about 5 times. Replaced the window module (used) but still the same issue. I just want to make sure if I replace the window motor I'm fixing the problem.
P.S. Anyone know if there is a non-OEM motor that will fit?
Many thanks in advance,
motorcarman (03-27-2023)
mhamilton
09-23-2013 09:19 PM
