Passenger seat recline down only
Hi, 1997 XK8 130,000 I am slowly resurrecting this car, and the 30th problem on the list is the passenger power seat, goes back and not back up. Has anyone had a similar problem, i already cleaned and checked the switch, the relay click in the seat module for down, but no click for up, are the module popular to go? a point in the right direction is always greatly appreciated. Chris
I just had the exact problem you have. Sorry to say it was a bad module and you can't buy one. I jumpered in a switch to run the backrest motor only. I made a small bracket so the switch was on the front side of the seat just under it. If you pull the seat out it is easy to see the wiring. I really like to keep things original but there isn't much choice here. It a module becomes available you can always convert the seat back.
chrisant (11-21-2010)
Most of the time this is a very common seat module fault, and can be repaired yourself if you have some basic soldering skill, or have a friend with some soldering skill, or take it to a local electronics repair guy. The plastic case wears away one or two circuit board traces at the edge of the circuit board. You carefully solder a thin wire to repair the traces.
See http://forums.roadfly.com/forums/jag...9317317-1.html
and https://www.jaguarforums.com/forum/s...+module+solder
That was a great piece of information, Removed the module, found the bad circuit trace "with a magnifier glass" soldered it, reinstalled it, and bingo! Saved me a lot of diagnosing time, and now i go onto repairing the other 20 problems Thank for all your help! Chris
WhiteXKR (11-22-2010)
I'll put my EE hat on:
Two reasons.
First this was a poor printed circuit board design. The thin copper foil printed circuit traces were designed so that they come in contact with the plastic case. Over time vibration causes the case to rub against the copper, wearing it away.
Second, the module was not conformally coated with a material (usually an acrylic or urethane is used) to protect it from environmental contaminants, which attack the exposed copper areas at the edge of the board over a period of years.
Two reasons.
Hi, Also having soldered the bad circuit trace, if you lay the board back into the plastic case, you will see the lip of plastic that rubbed the circuit board, i got a razor knife and shaved aprox. 1/16 of inch of the lip, so know it will not effect the repaired circuit trace, hence still plenty of support for the board. Thanks for all the help and input.. Chris
