Passenger window does not work
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
The connector is on the outside of the door between the door and the chassis on the hinge side of the door. The connector is round and you remove it by first turning it counter clockwise, this is locking connector, then pull it out. Mine made the clicking sound like you mentioned when I used the wnow swhich and the window was not working.To test the ground wire I found the ground wire on the harness going into the module , then I used a jump wire from there to the chassis and the window and mirror worked. That told me there was a bad ground between the door and chassis. After looking closer I found that the ground pin on the connector was corroded. Cleaned it up and no more problems. I don't know if this is your problem but it is worth a try.
BobRoy,
Thanks for your info on the door connector at the jamb. I took it apart and cleaned it but did not get a change in the window operation. Still dead! Was hoping to solve the issue without tearing into the door (looked for anything obvious externally first) but finally decided and had the time to take the door apart on Saturday. Panel off and speaker out. Reached in and probed around and immediately found the problem. SEE PHOTO!!!
![Icon Laugh](https://www.jaguarforums.com/forum/images/smilies/icon_laugh.gif)
Another simple fix!
Another simple fix!
teroks
10-02-2022 04:38 PM
xjrjag
04-14-2016 11:57 AM
