Passenger Window MisMove??
Recently when I lower the top on my '06 XK8, the passenger window starts down with the top moving up and back. It stops only half way down, and stays there until the top is fully lowered. I can then lower the driver driver side(it has not moved), and the 1/2 lowered passenger window with the driver's side switches.
Sometimes after I raise the top, the passenger window will suddenly decide to lower without no input from either side. I then have to activate the driver's side switch, twice(first time does nothing), to raise the passenger window. After that , I can raise or lower it from either side, normally. So far I have not taken the switch out to spray with WD40. That is my next step.
Something I can live with, just would rather not. Doe anyone have any ideas, or have seen this before?
Sam
Sam
It is in the door latch assembly in the door. Watch Reverend Sam's video of how to remove it. He replaced the entire assembly with one he found on ebay for $20 or so. It is much less expensive and far more practical to replace just the microswitch. I ordered several from mouser.com. The new Omron microswitch part number is D2SW-3L3MS. Order at least two of them because you will eventually be doing the other door as well. Wayne (cjd777) and I successfully replaced these microswitches in my wife's 2006 XK8 last April. Small, nimble hands definitely help when working to detach and later reattach the mechanical rods inside the doors....
For my synopsis of this job, see my thread entitled "Drivers Door Handle / Door Lock Problem"....
doc
10-13-2015 09:16 PM
newuser
Detailing / Car care
12-30-2010 06:24 PM
damianpenney
02-15-2010 12:27 AM
