Passenger window will not close fully RESOLVED
First of all, I want to thank the folks on this forum. As with out this forum, owning our 2002 XK8 would not be as thrilling for my wife. You folks have helped solve issues on more than one occasion keeping us away from the dealership.
With this said, I am hopeful for another quick fi for my wife's baby. The passenger side from window all of a sudden stop short of a full closure by 3-4 inches. I tried letting the window down and holding the bottom down for a few seconds. But, this does not reset the window.
Your help with this would be greatly appreciated.
Jamie
Jamie
Any experience with these symptoms?
Jamie
There is also this thread (linked in the Sticky):
https://www.jaguarforums.com/forum/x...26/#post207913
It has the JTIS procedure, which looks intimidating but isn't really that bad.
Can you put the window up with the door open? If you can, then it's probably the front or rear pitch adjustment causing it to dig into the seal.
If you can't raise it even with the door open, it might be the height stop.
Thanks for the information.
Jamie
Jamie
JimC64 (09-21-2014)
Received 9,009 Likes
I tried holding the up button to reset the window with no luck. I will be diving into the door panel in the next couple of days. I hope to find a loose bolt or something simple once I get it opened up.
Thanks to the members of this forum, the window is fixed. Now, I still have to tackle the hazard button (sticking) issue. Again, the forum has provided me with enough information to get me started.
Jamie
The following 2 users liked this post by JCam:
JimC64 (09-22-2014),
tompullizzi (12-09-2022)
99xk8guy
06-05-2023 06:28 AM
