passengers window has a mind of its own?
I am charging my battery now, the battery is a year old....
Drivers window is fine but passengers will lower on its own will while driving
When it goes fully down, if i hit the passengers UP button I hear the click but thats it, it doesnt go up....if I try it a few minutes later it may or may not go up (I always hear the click...I reset the window stops too (up and down) to no avail...ideas??
The window dropping when driving might be another issue not related to the battery. The door latch has several switches and the mechanism is often overlooked and never lubricated. Take a little WD-40 and spray it into the latch area and be sure not to overdo it and work the door several times. Give it a day or two before you replace the battery.
Swap the door control module with the driver’s side to see if it is the problem or one of the switches in the door latch mechanism. Link http://jagrepair.com/images/AutoRepa.../jagxk1999.pdf page 20 the same on your 2003
99xk8guy
06-05-2023 06:28 AM
RaceDiagnostics
09-13-2015 02:22 AM
