Patch up wheel arch liner
The ice that builds up under the fenders on the wheel liners cracked up my front liners very bad last year. I repaired then my taking them out and basically stitching them back together. I drilled matching holes either side of the crack and pulled it together with a tie wrap at each set of holes. Just pull hard enough to pull the joint together, then snip off the tie wrap and. I did this about every half inch. After I got the contours all correct I sprayed each side with spray flex seal, 3 coats and let it dry over night. It has held up well for over a year. Use the smallest size tie wraps you can find. I got black ones at the dollar store and then use a drill size that you can barely get the tie wrap through.
Blairware
08-21-2018 11:20 AM
nurquhar
08-27-2012 12:36 PM
SimoCat
04-23-2012 07:58 AM
adamedw87
04-28-2011 03:23 AM
