PDC
Hope you mean the Parking Assist Sensors (4) in rear cover. If you have good hearing, you can listen to see which one does not emit a clicking sound. I bought a Stethoscope at Harbor Freight and located my defective sensor, my hearing is shot. Must leave the car running in reverse with Park Brake engaged or you sit in car and get some one else to determine the one that's bad.
Received 1,701 Likes
there’s a safer way, without worrying the car is going to back over you.
on my ‘02 XKR coupe I just :
1) step on the brake to release the shifter solenoid.
2) Then turn the ignition key to on, without engaging the starter.
3) Then move the shifter to Reverse.
4) go to back of car and put ear to sensor(s).
If they are good you will hear a clicking sound.
no need to start the engine and trust the hand brake with your life.
Z
The following 3 users liked this post by zray:
Ant Buck (07-27-2022)
On my XKR the system works beautifully - let me know what I am missing.... On the XK8 (car is 215k now) all I get is NOTHING or a continuous beep, no spaces or speed variations... I've already fallen in LIKE with what I have in the parking assist in the XKR and would like to repair the XK8 system.
It wants to work, so I'm off to good start, I think!? Famous last words before entire rear end of car is off and on the ground, smh... My life, 😆
