Performance Upgrades
ZMann - the publisher of Jaguar World magazine just released a book about XK8/XKR - and it has several good articles in it about XK8/XKR performance upgrades and DIY-s articles.
They sell it online - and in the US it is sold exclusively through Barnes and Noble store. Check it out - I think you'd find something there.
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
Like others have said if you really want more power buy an XKR.But if you want to feel like you have more power,do the exhaust then the intake.There is a lot of guys with XK8's on the forum that have modified their exhaust systems,do a search on the subject.You may not go a lot faster but the growl will put a smile on your face.Keep us informed on what you decide to do.
"If I agreed with you,we'd both be wrong"
If reliability is a major concern, before you do any performance upgrades take care of the known reliability issues that are inherent with your model year !! That will probably eat up most of your "performance" budget. Like the consensus above, there is not much you can do that will make any significant difference performance wise on the normally aspirated motors. There are a bunch of little things but all together they add up to a lot of dollars and very little performance. Get the "R" if you are unhappy with the motor, handling or braking performance. You will be way ahead in the long run vs trying to upgrade the N/A motor, brakes or suspension.
I did put on an exhaust system and now have a very satisfying sound from the motor. The car is very quick from a safety standpoint (ability to get out of a bad situation using the accelerator) but I don't take on any rice rocket challengers due to the uncertainty of the outcome. If I was driving an "R", I would not hesitate to take them on, I'd probably win, I'd probably have a few thousand dollars worth of tickets and I might still have my D.L. Best of luck with whichever way you go. You have what I think is one of the best looking cars every designed with a great motor.
Trust me there is not a lot you can do to upset the reliability of these engines with the limited amount of things you can do. Assuming the inherent issues are done
1st put on an exhaust, wont give alot more power but sounds like it does which is a bonus.
2nd For godsake don't put on a cone filter unless you want induction noise and too loose power, the only cone filters that work are the ones in carbon canisters, buy a CDA but they are expensive, buy one of these instead http://www.cbsonline.co.uk/remote-ca...bfil-861-p.asp a lot cheaper and rated up to 350bhp which is enough for an 8 but not for an R.
3rd get a remap, no guarantees you will get big power gains but will help with the few things you have done.
That little lot probably just cost you $2500 and you 'might' of gained 10% more power
zmann96, have you adjusted your throttle cable yet? If not, you do not know what your missing... It takes about 1 min (okay 2) and you will not believe how amazing your car performs. It's not a "performance mod" per se... Instead you are just experiencing what the cars factory new performance was like.
My car is a 2000, and I had at least an inch more travel available. Yours being a '99 I suspect you'll have the same AMAZING (feels like you got an "R" upgrade) results.
Here are the instructions:
https://www.jaguarforums.com/forum/s...t=38663&page=5
Be sure to thank hlgeorge for the good work.
rominempire
28
10-08-2020 10:39 AM
