phone interface connection & star tac jag phone
hi need some help have just brought a phone interface for my xk8 was told it was the same as xj it has the white connector my xk has the yellow connector all the wires are the same but they are both male connectors have joined all the wires that are the same colour the startac has the jaguar software it all works can dial out recieve calls the only thing is there is a lot of feed back and seems like there is no mike have connected one does any one have a wiring diagram mybe the wires need swopping about thanks
Mic. (overhead console)...A pillar...........Under console (Yellow 18X Connector)
+ RF9-1 (White).............RF1-17.........RT1-1..(White)
- RF9-2 (Green).............RF1-19.........RT1-3..(Green)
Yellow wire with (shield) RF1-18.........RT1-2..(Yellow) this shield starts at Conn RF1
If you let us know the year of your car and an Email Addr. will send Diagram.
Also the period key on your K/B apparently has failed.
nick, they're just giving you some grief for the lack of any capitalization or punctuation in your original post. It is sometimes difficult to read with so many runon sentences.
You can PM (personal message) FJK if you like, simply click on his screename and hit the 'send message to -'. That will keep your email address from being seen on a public forum.
g'luck!
g'luck!
hi i had no trouble reading it but then i have had way too much coffee and this is the way im thinking right now like just a lot of run on sentences sometimes with multiple streams of thought all at once but sometimes not but hey what do you do so does anyone else get really po'd at the shift and punctuation thing at just slows everything down when i type so i say we just do away with it and type like this all jumbled and stuff and junk thanks ps i need beer
Can't you read? He had the time portal activated. That allows him to go back in time to a period when phones were actually attached to the cars. Or maybe he wants to go back to 1996 when the StarTac phone was introduced.
hi - i post the message so that anyone researching phone options with the car can see how you can hookup the original phone instead of Jerry rigging a work around that doesn't use all the original functionality...the info I found would hav been useful when I was first reading the thread...hence the reason i posted it...
