Photos Schrader valve on fuel rail location
Friends, we've mentioned this many times, don't think I've seen photos of the location before. I was helping someone out today, figured I'd post this here for future reference for all to use. John
***edit: the gold valve was covered with a blue plastic cap. Removed for photo.
General location for orientation.
See gold valve.
See gold valve.
The following 6 users liked this post by Johnken:
DavidYau (03-17-2020),
michaelh (02-17-2022),
motorcarman (03-16-2020),
Orthodixie (10-18-2020),
ozbot (03-16-2020),
and 1 others liked this post.
The following 2 users liked this post by motorcarman:
Johnken (03-16-2020),
The following 2 users liked this post by cjd777:
Johnken (03-17-2020),
It certainly is a great tool in a no start situation. '
Had a problem back in January and after checking the usual suspects, pushed the valve and got a dribble of fuel after several attempts to get a reaction from the motor. Changed relays and checked fuses and quickly decided to go in the trunk and hear for any humming. None, so fuel filter was the last thing I could rule out.
Replacement if not a lot of fun, but found a much better way to get the lines off and replace, so in the end will help others. Saved going the gauntlet of electrical connection hunting by a simple push of a button, so to speak.
This is Jaguar's explanation for the omission of the schrader valve in the X Type for MY2004. You can guess that the same reasoning accounts for the X100's loss!
Fuel Tank and Lines (AWD variants) Introduction
The vehicle has a new fuel system designed to meet USA Federal LEV 2 emissions requirements.
Parts affected are:
• Under floor fuel lines.
• Fuel tank assembly.
• Fuel filler pipe.
• Carbon canister.
• Fuel filler cap.
Service Port
In order to further reduce emissions, the fuel rail ’schraeder’
valve is deleted. Should a service port be needed, a new
service special tool will be available to fit between the fuel
rail and the fuel feed line connection.
Parts affected are:
• Fuel filler pipe.
• Carbon canister.
• Fuel filler cap.
Service Port
The following 2 users liked this post by astromorg:
Johnken (03-24-2020),
MikeAlford (10-20-2020)
Service Port
Service Port
When the Earth's environment is threatened by emissions from my fuel rail schrader valve, I'm getting off this ride and looking for a new planet.
astromorg (10-18-2020)
Tony K
02-23-2015 09:24 AM
