Picking up my 2005 Jaguar XK coupe tomorrow
Hi guys,
I'll be picking my new 2005 XK8 coupe tomorrow...the car currently only has 36K miles on it and has a check engine (P0455) which leads me to the canister purge valve? I read that it's a common issue for this car. Anyway, I wonder what kind of preventative maintenance that I should tackle right away? at 36 K would the plugs needs change? tranny fluids? differential fluids? I came from Saab World (well still do) so I usually do my maintenance myself. This would be my first V8 ...yeees..
2. Where would majority of you find get your parts from? As soon as I drive it home from San Jose to Oregon (with the P0455 code on) I will replace the canister right away.
Thank you guys ...any tips on how I can make sure this Jag last a long time would be appreciated.
With a new (to me) Jaguar, regardless of how good the history looks, I always carry out all the items on the Service Schedule to give me a base line for future servicing.
XK Maintenance Schedules 2005.pdf
The one thing I usually do leave out is changing spark plugs. The recommended change interval is 100K miles.
Transmission fluid change is an obvious preventative maintenance task as is checking battery age and condition because these cars are very sensitive to charge level.
Excellent advice from Graham above....
Study the stickied threads at the top of the XK8 forum. You have much to learn and this is one of the best ways to get up-to-speed quickly. There are many long-time owners here so if you explain your problem in detail in decent English, chances are that you'll get the help you need....
Dealership parts prices are usually quite high. Our cars were built when Ford owned the lion's share of Jaguar so a few parts can sometimes be sourced there. Other options include our forum sponsors such as SNG Barratt Group. Call them at (800) 452-4787 and ask them to mail you their fantastic XK8 parts catalog. It is invaluable for these cars and it is FREE. Call them today....
Good luck and welcome to the forum. As you will quickly learn, it will become by far the most important tool in your toolbox....
zidjan (02-18-2015)
Thank you guysss!!! thank's for the quick reply... yes I know I have been reading a lot about the XK8 issues and weaknesses...I am glad I ended up with a 2005 ...no tensioner issue to think about.....I've been reading some of the how to's and yes that's the reason I ended up buying the Jag rather than a Boxster (my other choice)...because the Jag seems a little easier to maintain although I am sure the Boxster can provide me a better smile/dollar. Anyway, you know I'll be coming to this forum a lot for advice...I've been reading about the P0455 now....so let's see where mine will land (broken hose or canister).
![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
Best advise is to actually believe every word these folks say about the battery charge level. I had gremlins that only disappeared when I broke down and replaced a battery that tested OK, but just barely. Forget what you might have experienced on other cars in this regard. Jaguars love the juice.
zidjan (02-19-2015)
And at least 12.3 volts after 8 hours without the engine running is a good rough guideline for the battery.
zidjan (02-19-2015)
No harm driving with the P0455 unless you have an overwhelming fuel odor. Before replacing the purge valve, inspect the plastic and rubber pipework under the car connected to the two rectangular black plastic boxes (the charcoal canisters) between the rear wheels. A detached, or broken plastic vapor pipe, or a deteriorated rubber hose could cause this also.
Did you see an Alpine green 99 XK8 headed South on a transporter, down I-5, on your way home? I expect to take delivery today here in Grants Pass. Aren't new toys fun. ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Russ
Russ
Haha..I havent left Sacramento yet...but I'll be sure to look out for It... and report back if I see a green xk8 :-)
For you experienced xk-er out there....when i drive the car aside from immense pleasure I got out of the 4.2 v8, I notice steering vibration at highway speed.... my wife doesn't feel it...I am guessing its just the steering....which means steering bushing? I'm going to tackle the p0455 first thing, maybe change the steering bushing, check the battery voltage, get her a full treatment at the spa (full details) and start shopping for exhaust....anything else?
I tried it last night...although at 50mph the steering doesn't shake....I haven't try it at 70mph maybe i'll do that today....what's wrong with it if it only shakes at higher speed? up to 80 mph and then it's fine.
zidjan (02-22-2015)
No one's mentioned this yet and while you have a 05 (10 yrs old) the front suspension components will cause this, I had a shake at 70 thought 55 was fine. There are a number of threads on this issue if you do a search some with video on how to do any repairs. Items are top/lower shock mounts, bushings and ball joints. Of course due your due diligence on alignment, note many tire centers won't have the shim kits available to make the alignments but get your readings and post them here on the forums other members can comment on what's acceptable vs needed corrected.
Welcome to the forums and enjoy your new ride..
