Pics of new XKR wheels - two Montreals available.
5x120 is fine.... I have aftermarket wheels on mine and the 120 fits perfect (after all, .65 mm is LESS than a 32nd of an inch).
You DO however have to be concerned about the Hub Bore (ours is 73.9mm, I believe) as well as the offset. I had to have my wheels bored out like 2mm for them to fit (and our wheels are hub-centric as well so if the bore is larger you will need hub-centric rings to fill in the gap between the center hub and the rim).
