Pics for rear alignment shims FIXED
After lowering the rear end I will no doubt need some camber shims. I'm wondering if there are any shims already installed, and if they show up in any of these pics. The first one is the right differential flange area, the second and third are the left side. If they're some installled, could someone point them out? If none are installed, where do they go? Thanks...
I can see what looks like a spacer or bushing in between the axle and diff flange, but a shim would be hidden from view?
The factory shims seem to be about 4mm as installed and I always keep a few 6mm shims to bring with me to the alignment shop to get the camber corrected on the XK/XJ Jags.
I seem to remember that they used to be cheaper but lately they are around $40.00 USD each.
I think 7.5mm is the MAX size issued from Jaguar but you can stack two 4mm to get 8mm or even more as long as the studs still have enough threads to keep the flange on.
bob gauff
bob gauff
Skid Mark (02-06-2012)
bob gauff
bob gauff
Then I'll run it to a local Jag dealer for a free alignment check which it should pass with flying colors, unless lowering the rear threw out the front end alignment, which will then render the entire situation utterly hopeless.
Did find some shims from partsxjs.com here: Driveshaft and Half Shafts for $26 each + shipping. I thought about using a 4.0mm shim on the right side, but for some reason they were $45 along with a few others.
99xk8guy
06-05-2023 06:28 AM
RoyLittle0
05-25-2023 02:38 AM
