A-pillar airbag sensor removal
NO it doesn't.
The push-in tabs on plastic components are very quick for production line assembly but always a nightmare to subsequently dismantle even when you know exactly where to push to release them.
The metal spring clips like the one in your photo are another joy to disassemble - they have teeth like a rabid dog!
I just finished reupholstering my A-pillar. The sensor mounts with a simple torx screw and washer which holds the sensor against the back of the A-pillar. The plastic which holds the screw breaks easily, and it appears in your case a previous owner (or mechanic) broke the plastic screw housing and then glued it back in. I would just carefully cut the glue with a utility knife to free up the sensor for removal.
alecescolme
04-05-2017 01:58 PM
car5car
03-19-2015 09:46 PM
locorebob
07-17-2011 08:17 AM
