Pink head light??
GGG (10-15-2015)
Vern makes a very valid point in post #2. Model and Year are essential information when posting questions. I'll also add that Location (Country + City or State) can often make a difference.
If you have an early model it's likely to be simply a failing bulb. For later models with self leveling HID's it could be either bulb or ballast.
For all years access for bulb replacement is from the engine compartment except for the dipped beam bulb which is accessible through a panel in the front of the wheelarch liner.
The following 3 users liked this post by GGG:
For a 2003 MY you could have standard or HID lighting. Different bulbs and alignment procedures but accessing the bulbs for changing is similar:
(click on the images to enlarge them)
Working though the top of the headlamp shell after removing the plastic cap is awkward for anyone with large hands but there's nothing technically difficult in the bulb replacement.
Attachment 119966
Attachment 119967
Attachment 119968
Attachment 119966
Attachment 119967
Attachment 119968
Ok, thanks for the info and diagrams!
RESOVLED!
RESOLVED!
So after many weeks, yesterday my pink headlight finally went out. It still comes on at start-up, bright as it should be, but quickly fades to pink as it has been doing for about 6 weeks now. However as of yesterday it now goes out completely about a minute after start-up.
The bulbs I ordered showed up the day before yesterday, so some good timing there. (I went with cheap Chinese D1S bulbs to see how they perform. I hope it will not effect the ballast or cause any other issues, but this is the only way to find out.)
As a side note, I went to the local JagLR dealer to compare costs and they quoted me $326.95 (incl. 13% tax) for the part (1 only - D1S bulb) and $125.00 to install it. Needless to say I was nearly rolling on the floor laughing as I left the dealership without buying any of their parts nor services. (Since I was there I also priced their "OEM" Jag transmission fluid - $56.95 a litre, (comparing Mercon SP @ ~$7 / quart). The only reasonable items were the tranny filter and pan gasket at just over $100 for the pair.
So today it was warm enough (~12* C) for me to install the bulb. Twenty minutes, a few scraped fingers and knuckles and one broken fingernail later, it is as good as new. It's a pain in the *** to install because of the tight quarters, especially without removing the wheel. (Passenger side.)
This has prompted a few questions. The bulb I removed was an OSRAM make. I wonder if this might be the original bulb? I know they can last anywhere from 2000 to 3000 hours. It may be as my car has ~110K miles on it. (110,000 / ~35 MPH avg. speed = 3,142 hours of life, give or take considering idling and hwy. mixed driving.) It sure looked old, but it could be a replacement.
So for those with HID headlights, how long have your bulbs lasted on average? And what make of bulb have you chosen to use as a replacement? (Phillips, OSRAM, GE, or other?)
FS[Central US]: 2000 XJR 117,000 miles mechanic owned turn key car, $5000
tylerh860
11-17-2015 10:14 AM
