Plastic thermostat housing
#41
#43
I've been a "light" mechanic for many years, a Jag owner for only 4, and a new member to this forum for only a few months and find it mostly very helpful. A broken pully, belt and resevoir hose led to overheating and an small leak from the therm housing onto the engine block on my 4.0 L XK8. I spent almost an hour trying to attack the two rear 6 mm bolts or remove the intake manifold which seemed so unnecessary if I could just get " the right tools"
After reading all your posts,, I was on my way to a welder when I stopped at a NAPA store. They sell a 8 / 10 mm brake bleader wrench made by Evercraft service tools, which is almost perfect for the job. It did break the rear bolts without modification of the tool and I used a curved long needle nose and a " cut down" 8 mm 1/4 inch drive socket for the rest of the rear bolt removal.
Based on other post info, I was going to re-install with the screw driver slot idea, but thien I found 2 6m - 1.00 x 20 cap screw bolts for the rear, and 2 6m 1.00 25 (same as original length) for the front bolts and installed them very easily with a 5mm ball hex driver 3/8 drive socket,, the ball end give you torque as well as a small angle for easy verticle installation. .... I hope these ideas help others in the future... and now on to fix the neg camber problem
#46
On my two cars the thermostat housing has been replaced on each once under warranty and I replaced one moving to aluminum after a second leak. Pretty good chance that yours is going to fail at some time. Fortunately, the failure is a soft one, slowly showing crusty yellow/orange around the base without catastrophic coolant leaks. That fits well with my philosophy of not fixing anything that is not broke.
I have crusting on my 2005 xk8 4.2 a replacement part is no longer made. I have searched any suggestions .
#47
#48
mikiep
12-20-2019 07:37 PM
02, 2000, 2002, change, failure, gotd, housing, jaguar, plastic, replac, replace, replacement, requirements, thermostat, xk8
