Plastic water pump vanes in a 2006???
I have a "howling" sound my mechanic is tracking down. We were pretty sure it was coming from the water pump. Replaced it. When I saw what he took out I was quite surprised. The pump had plastic impeller vanes. They were in good shape. But they were plastic. I thought plastic was replaced by metal early in the run. My 2006 was built within 50 cars of the end of the XK8 run.
I bought the car in 2010 with around 45,000 miles. It is conceivable (but not likely) the previous owner replaced the pump.
Even so, why would it be plastic?
Bit of a mystery.
... The sound went away after replacing the pump. It shortly returned. We are looking at the other pulleys as the source of the howl.
Thank you,
Jack
Bit of a mystery.
Thank you,
Jack
BlkCat (01-05-2016)
Nothing wrong with plastic impellers when they are the correct type of material. The water pump with plastic impeller in my wife's BMW is still fine after 12 years and 180,000 miles. BMW tech did not recommend replacing it when I asked, and said his had 240,000 miles on it.
BlkCat (01-08-2016)
I had a howling sound on startup on a 2005 Ford V6 engine. Had both tensioner wheels replaced, the sound was worst. Started to remove fan in order to replace the water pump, found the harmonic damper had broken into two pieces, the outer pulley had separated from the hub. The two pieces are attached by a flexable material which fractures and finally failed.
Don't know if Jaguar used this design but you can get it checked.
BlkCat (01-08-2016)
Highhorse
02-20-2016 10:18 AM
Roger Mabry
01-03-2016 07:53 PM
