Please help!!!
Hi I have a 2000 xk8 with air bag code Blink cod 52.
After purchasing IDS software, lap top and mongoose cable it says no communication with module.
I have replsced the module from a car that did not have an air bag deployment. Checked all fuses wiring and connections under seats and numerous grounds
The only lead I have is the DLC connector is only showing 4.3 volts at pin 3 which is a direct communication wire to the air bag module. (Which is the same voltage reading ad the original module.
I'm out of idea's please help if you can.
thanks
thanks
2000blackxkr
09-28-2010 08:13 AM
