Please Help. Battery and No Start
The inertia switch has a button at the top which must be pressed down fully...never know one to be intermittent but possible. Can get triggered by a big pothole etc
You could check if you have 12v at one of the live bolts near the LH under bonnet fuse boxes ...a bulb is better than a digital meter..headlamp bulb would be perfect.
Note to the wise ..."get misled use a digital voltmeter"
I guess you're right, I must be blessed that so far few if any electrical gremlins have crept into this car, nor into my previous XJ6, nor my 1974 Range Rover but of course I am aware of others having many problems as I did with a Citroën CX2500 which failed due to corroded spade connectors and that was probably about 10 years old. It was however, French. Great but flawed car.
Sorry, of course the most complicated electronics the RR had was that terrible electronic ignition which I suspect came with a retro fitted V8. Amazingly I was grumbling to a friend that I couldn't get it to work properly and it turned out he was on the development team for it and he put me on the right track. Mine was a pure off road car, bob tailed, lifted a bit and a load of smaller changes. Painted NATO matt black - some sort of paint that reduced detection which couldn't possibly have worked. But cheap and could be applied with a roller.
Thank you
I did get the car running. I believe it was battery voltage
Battery was fine. Battery tester showed 12.2 bolts and 745 cold cranking amps. Wouldn’t start. Put a jump box on it and it started. Since then it’s started several times on its own fine.
Received 1,702 Likes
One cannot treat a 20 year old car with miles of wiring like it was brand new.
Z
The following 2 users liked this post by zray:
Abby's Guy (05-09-2022),
JWestXJR2000 (05-15-2022)
