Please post a photo of your floor mat hooks!
Yeah, I know. Kinda weird. And not a very compelling request. But I'd really appreciate getting a close, personal look at the hooks that hold your floor mats in place.
My car, a 1997, currently has none. There are two round holes in both the driver and passenger carpets for hooks, but no hooks.
The only hook that Jag currently distributes for our cars is part number JLM 20428. I've now purchased four of these hooks, but as you can see from the photo below, the official part and the current hole in the carpet (which matches a hole in the body / flooring below) don't really match up.
![Name: FloormathookwithexistingholeNov2012.jpg
Size: 259.1 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/158994d1501262793-please-post-photo-your-floor-mat-hooks-floormathookwithexistingholenov2012.jpg)
The bottom, flat section of this part is hinged on the right, and snaps into the top section on the left. I assume there should be two holes in the carpet holding this piece in place, with the black top piece exposed. Is that right?
Here's a closer shot of the current holes in the carpet, with the matching hole in the floor / bodywork. It's almost as if a hook used to screw in somehow.
![Name: ExistingholeforfloormathookNov2012.jpg
Size: 103.3 KB](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/158995d1501262793-please-post-photo-your-floor-mat-hooks-existingholeforfloormathooknov2012.jpg)
Anyway, it would be helpful if I could get a quick look at what a few of you have for floor mat hooks. Please post away! And thanks.
Here is what I have in my 2001 XK8. It didn't see how to pull them out, but it appears they "clip" to the bottom carpet piece for the mat to hook on. The little ridges on the inside of the bottom clip keep it from moving. Perhaps the hole is to seat the front section of the clip.
Also looks like there is a slit in the bottom carpet piece for this clip to slide in so you end up with it above and below the carpet. Once in place, the mat hooks on.
Hope this helps.
Hope this helps.
The Coupe (11-09-2012)
The Coupe (11-10-2012)
Good morning.
There are no hooks, but some fairly large plastic studs/screws that go through the holes in the carpet and screw/twist into the floor. No cutting in the carpet please.
I have no pictures right now as I am in my pyjamas sipping my morning coffee and it is cold outside, but I will try to get some.
The hooks you have pictured are the type I have in my X-type.
Here's the kind of hook you've got fitted in my XK8. Only one hook per side on the later models:
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-17/25838d1352539494-please-post-photo-your-floor-mat-hooks-dsc_0165-jpg)
There's a slot cut in the carpet for the front of the hook. It clips together through the existing rear hole in the carpet.
The hook only fits to the carpet. it isn't stuck to the vehicle floor.
Excellent! My European friends have answered the call, while those of us in the US slept.
Oyster, you've got a 1997 just as I do, and I feel sure that my original, OE floor mats were secured just like yours. I assume you just push the piece straight down into the hole, the ribs hold it in place, and you pry it out when you need to, yes?
I feel sure I can find something similar that will work.
GGG, thank you for your photo as well...if I don't find something like Oyster's push-in type I will bring out the razor blade.
And thank you, Frog - I hope you're happy and healthy.
........................... Oyster, you've got a 1997 just as I do, and I feel sure that my original, OE floor mats were secured just like yours. I assume you just push the piece straight down into the hole, the ribs hold it in place, and you pry it out when you need to, yes? ......
The fixing in Oyster's pics is a Turn Stud (item 4) and it fastens into a Cam Plate (item 3):
Part Numbers
Cam Plate : KRF100001
Turn Stud : AGU2229xxx
For the Turn Stud, 'xxx' will be the Trim Code for your vehicle.
The following 4 users liked this post by GGG:
The floor mats are very easy to remove from the later 'single hook' type of fixing whilst being securely held when in use.
Mbourne
09-14-2015 09:21 PM
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
