Please take pity and answer timing tensioner question
Hello,
I know there are a lot of posts already, but they tend to get confusing answers.
I have a 2000 XK8 with 36,000 miles. I want to be proactive and have the tensioners changed to the best metal version available. The mechanic shop likes to use OEM as much as possible. Where would I source the upgraded replacements from, a Lincoln vendor? Is there a kit with both upper and lower tensioners, chains, guides, and gaskets?
Thank you for your help.
Rande
Rande
Received 2,396 Likes
See this post from BobRoy:
https://www.jaguarforums.com/forum/x...6/#post2135756
Note the caveat regarding the primary slipper guides
At 36,000 miles, consider re-using the original chains.
linconlsv8
09-17-2014 03:27 AM
