Plug Coil Supplier?
Plug Coil Supplier?
I recently had a misfire on #5, replaced coil with Denso at $250 from Jag dealer. Just had another failure on #2, replaced it with BWD from local parts shop at $175. I need to do them all and the plugs too but there has to be a better source. Can anyone recommend a manufacturer and part number at reasonable cost? 1999 4.0, 110000 km.
kstevusa (05-02-2022)
michaelh (05-02-2022)
Received 1,702 Likes
I recall someone on the forum had purchased a set of NGK coils from RockAuto only to find out some of the boxes contained parts with coils made by unknown manufacturer, not NGK markings.
So check all coils markings to make sure you are getting the quality paid for.
But to answer the question, yes, stick with NGK for best results. I think the Denso coils for the XKR’s are no longer easily found.
Z
Z
