PO 171
As a new member you may not have reached the minimum post yet to have full access to do searches.
I have attached the definition for the P0171 code you are receiving. It also lists possible causes. I would first check the air inlet pipe bottom side for cracks in the convoluted area. A pretty common problem.
The most likely cause of the code is a vacuum leak allowing un-metered air into the system.
GGG (05-06-2018)
Chuck Schexnayder
12-21-2016 11:10 AM
Simon.h
70
11-25-2012 06:56 AM
