polyurethane foam in the frame of the car
Have never heard of using foam for stiffening.
For sound dampening yes, but the polyurethane foams, open or closed cell, don't have enough rigidity that I can imagine they would do much.
Think of a memory foam mattress or pillow... how is that stuff going to make a chassis more rigid.
Well ... So now, thanks to me, you are aware of this!
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Henkel - Virtual Car 2011 - Applications
1991 Nissan Sentra SE-R - Transformation Of A Classic - Turbo & High-Tech Performance
Polyurethene foam is used a lot in boatbuilding both for stiffening, and as a "former" for GRP. I have a GRP rudder full of the stuff. I think it's inside most surfboards. It's the same stuff you can get in aerosols for sealing and insulation in building construction. Once set, it can be moulded, cut and shaped. If I lived in a climate where it never EVER rained, I might consider injecting it into hollow chassis members and other cavities in a steel car for sound insulation and maybe a bit of extra rigidity but I would not contemplate doing that where moisture could be present. Capilliary action would suck the moisture into any gaps between the foam and the steel, and a few weeks later, you would have rust from the inside out.
The following 2 users liked this post by DevonDavid:
mrplow58 (07-24-2015),
User 070620 (07-17-2015)
Mike
as regards the injection of the foam, I think you use a high density foam (which does not absorb liquids) and before injecting into the cavities of the frame, the wax is sprayed in (that normally use refinishers to protect the joints) that does not allow to possible infiltration of turning into rust.
There's a TSB somewhere about resolving noise from the a-pillar area on the XK100. The solution? Fill the a-pillar cavity with expanding foam from an aerosol.
I don't recall hearing anything about a-pillar corrosion so maybe it's not quite as bad an idea as it sounds, or maybe moisture doesn't get trapped in that area anyway.
read what "TDI PLC" wrote about chassis of our XK8/R
Jaguar XKR Chassis and Suspension Upgrade
Perhaps the problems of the frame with this treatment ... could be solved?
more experience on this topic on Nissan Z32
Z32 Chassis Stiffening 101 - TexasNissans.com
Have used expanding foam a lot in various cars in A/B/D?E pillars to stop noise transmission to roof. Blocks of foam that expand fully as a car passes throgh the paint oven are used on a lot of new vehicles to reduce noise, add stiffness and improve crash performance. I do agree that the stuff should not be used in sills and chassis sections that get wet and need to drain.
User 070620 (07-21-2015)
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
