Possible wheel bearing failure?
When I brake lightly at a junction and turn right there is a grinding noise from the front left wheel. It just passed it's MOT a couple of weeks ago and nothing was brought up then apart from the anti-roll bar drop links which where an advisory. I had them replaced just after the MOT. Does this sound like a wheel bearing gone bad? Doesn't always do it either mostly when I am braking. I don't have any real wobble at speed either. I am just more suprised it wasn't picked up on the MOT if it is a bearing.
kstevusa (03-17-2022)
Edit: I got under the car a bit more to see if I could see anything out of the ordinary. Only thing I could see that looked wrong was not the anti-roll bar but the second bar closer to the front of the car, the bushing on the passenger side looks like it rubs against one of the lower suspention arms. I don't know what that bar is though, second anti-roll bar? Anyway the busshing is rubbing on the lower control arm where it mounts to the car. The rubber is supple though so I can't think it would be that noisey. When it is bright out I think I will check the bolts on the links to make sure they are tight, how tight should they be? I suppose it is also possible the sway bar link is faulty, I may need to see if I can replicate that noise though, will need to get some leverage on it though to see if I can make it make a noise I guess.
K, sorry I didn't recognize the 2nd bar description. But when reading your symptoms it reminded me of the time the anti sway bar bracket (open hood, look downwards by the headlight for the swaybar coming through the wheel well. Bracket is u shaped 2 bolts go straight down through Bracket into frame). The fact that you can move sway bar with your hand amplifies this possibly as the issue. Maybe give it a look.
John
John
Received 2,390 Likes
At first I thought it was that one but it's not. I can't see where it connects but there is a bushing for the grey coloured bar, it looks just like an anti-roll bar so it's cylindrical but it's not the anti roll bar because that is black. The bar I am talking about runs in-front of the front wheels. I will get a photo of it tomorrow when it's light out.
John
John
That is the bushing and the bar I can see on the front end of the car, it's touching the lower control arm but it doesn't seem to actually be rubbing.
When I am stationary and move the steering wheel to the right and left there is a lot of squeaks. Ball joint? It's hard to tell where it's coming from to be honest. I think it's most likely a bushing in the suspension somewhere, I don't think a bearing would squeak when stationary and turning the wheel. I figure that the anti-roll bar drop links being repalced put more pressure on something else causing that to wear fast. Lower shock bushing perhaps, I don't know. They are rather rusty.
Hi,
That is one of your A/C lines. It seems to be slightly in the wrong location? See posts 2 & 4 from PKWise in this thread:
https://www.jaguarforums.com/forum/x...7/#post2454770
Hi,
Daim
01-31-2018 04:24 AM
