Posting pictures
We have a lengthy thread on posting pictures in Jaguar Forums Advice / Feedback & Suggestion Center:
https://www.jaguarforums.com/forum/j...pictures-2418/
I have read the post. I don't use facebook or any other site like that. But as I said I can load to the album. But nowhere in my control panel does it tell me how to go to the gargar to load pictures. I can go to the garage an see there is nothing there. How do I put something in there once I'm there. And what is the difference between garage and album???
Received 4,280 Likes
EZDriver - if you look at your avatar, just underneath your profile name - it says garage is empty, add now. Click that link and you should be able to add a vehicle to your garage - this includes specs, pics, etc - as much detail as you want.
The other option is to click the Uesr CP link in the upper left. When that opens - click the Your Profile link - this will display several tabs - look for the one labeled Garage - click that tab and it will guide you.
Regards,
Steve
Regards,
Steve
EZDriver (12-29-2013)
Neil - to add pictures into a post - DO NOT click the insert image from the basic reply. Scroll down and click the Go Advanced button. Once you do this, you will see a few extra options above the basic tool bar - one of which looks like a paper clip.
Select the paper clip and a window will open - click the choose file button and it will open a windows explorer window allowing you to search for the picture you want.
Once you have the picture highlighted, click open - you will then see the file name next to the "choose file" button. click the upload button to the right of the file name - you will then see the file as an attachment. You can add additional pics or if done, scroll down and select "Close window"
Hope this helps
Regards,
Steve
Hope this helps
Regards,
Steve
Received 6,307 Likes
This post from Graham from thread https://www.jaguarforums.com/forum/j...63/#post619210 may help.
1. click on Garage is empty, add now link next to your avatar
2. click on Add new vehicle link
3. fill in basic vehicle info in Step 1 dialogue box
4. go to Step 4 dialogue box and browse to locate your vehicle pic
5. add the pic then press Save changes button at the bottom of the screen
clubairth1
29
05-10-2024 12:57 PM
Mbourne
09-14-2015 09:21 PM
