Power loss @ different RPMs 2006 XKR
So my 06 XKR finally arrived yesterday.
It drives fine until you give it some. Then it pulls well until around 3000RPM and then feels as though the rev limiter is kicking in. If I keep my foot on the gas, it eventually gets power again up to around 4200RPM when it again loses power. Keep my foot on the gas and it gets power again and pulls nicely to redline.
The gas tank was almost empty when I got the car so I have filled it up with premium gas.
Any ideas?
Any ideas?
TX_Brit (05-18-2017)
Do yourself a favor and spend a few dollars on an ELM327 OBDII adapter from eBay and the TorquePro app for Android (or iPhone equivalent). This will give you a wealth of information, including your fuel pressure (clogged filter, etc), fuel trims (vacuum leaks, air flow meter), air flow, water temp, etc., in addition to any standard OBDII codes.
Best of luck, keep us posted.
TX_Brit (05-19-2017)
