Power Seat Stopped Working!!!
#41
#42
Hi Brian - I tried reworking one edge trace on my seat control board over a year ago and failed. You have 100% success! That's not just luck. Is the problem always a damaged edge trace? Do you have ways of checking out more aspects of a seat control module, like failed components? I'm in Culver City and work in El Segundo, so if you're in Manhattan Beach, we're neighbors. Thanks. Mark 310-988-6184
#43
I find that most of the time, a jumper wirre is necessary to fix the open. They always run along the edge due to the way it rests on the housing. The most common break require a wire to be soldered between an IC and a relay. This is for the seatback forward control. Let me know if you need help.
markaltobelli2002 (11-24-2012)
#44
Thanks, Brian. IC to relay sounds foolproof if I can't patch the edge trace.
Are pin-out assignments for the connector to seat module and/or schematics of the board available somewhere? I can't find where the forum has technical info stashed, though I've read it's here somewhere. Please help me navigate to it. Thanks!
#45
#46
The module pinouts can be found in the electrical diagram's on Gus' website:
JagRepair.com - Jaguar Repair Information Resource
#47
I just wanted to say that I had kind of the same problem in my 99. The seat forward and back button made a noise but didn't move, but all the other controls worked.
I went to try to find the module, lifted up the seat, it must have been stuck on the wires or something down there, because now it goes forward and backward, so I moved it back, and put it back down, it is stuck again from going forward and backward, but at least now I can put the seat in the proper driving position and drive it.
May help someone out
#48
While removing the driver-side floor mat in my wife's XK8 last evening to shake the dirt and leaves out of it, I noticed that her driver-side seat module is loosely in place underneath the seat and appears to be held together by a red-colored zip-tie strap. Checking the passenger-side seat module, it was tightly in place underneath the seat with no evidence of any zip-tie straps....
Should I assume this means that at some point her driver-side seat module failed and has been pulled out, had its circuit board re-soldered, and re-installed?
Is this strictly a DIY fix by the savvy owner, or have Jaguar dealership techs been known to do these repairs as well? I would not be surprised if Brutal has done this repair for some of his customers to save them considerable money....
#49
Fuses first, #1 and #8 on the driver's fascia fuse panel.
The cars have a history of rubbing through the wiring insulation under the seat.
If fuses are good might try swapping the seat control module with the passenger side. Two small bolts each and the connectors make this a easy job. The modules have a history of breaking a circuit board conductor along the edge. Several members have repaired with a small piece of wire and solder.
Best wishes, Colin
#50
aardvark64 (04-29-2013)
#51
Hiii i have a problem with my passenger saet > Head rest is working but recline and forwards backwards is not working anymore . My seat is blocked in a position that i can't reached the fixing bolt of the rails . Any boby with a solution how i can remove my seat now to check the seat control box Thanks
#54
hii test point
I could remove the seat module thanks to your information .
I switched the driver seat module with the Passenger seats module .
Results The module doesn't work on the driver seat and the drivers seats module works perfectly on the passengers seats . I opened the one that is not working . Nothing seems broken or burned inside . Is it possible there is a problem with the program ? Anyway i found a second hand one of a later XK . The part number is LNC2160AD and works perfectly Thanks again for all the information
#55
#56
View a few YouTube videos on electronics soldering basics if you have never done this before.
#57
#58
Where's a good place to have my bad seat modules repaired? I tried the repair, unsuccessfully. Have six dead modules (and two good, on 4 XK8's). I'd rather have mine tested and repaired than gamble by buying used ones.
My greatest wish, by the way:
Is there an XK8 mechanic or shop in Los Angeles area, honest and expert, able and willing to correctly diagnosis and repair XK8s cost-effectively? Or at least, honest and expert? Thanks
#59
Soldering wires to replace the broken traces bypasses the susceptible traces and should be a permanent fix.
