Power Seat Wiring
Power Seat Wiring
Hello all. I have a memory controlled driver's seat. I have been able to get most functions working. Now I'm down to one last issue -- the seat bottom up/down.
I have the electrical schematic for my model year. I have verified proper operation for the switches on the side of the seat. I can hear the relay clicking when up or down are selected.
I removed the seat. I removed the seat motors. I used a small battery to bench test the motors, and observed each capable of rotating clockwise and counter clockwise.
Now I'm stuck. I'm guess the problem is somewhere between the relay output of the seat module, and the wiring up to the up/down seat motors.
Does anybody have a suggestion what to try next?
Very respectfully, Bob G.
I know a little about the seat switch. They are very simple devices. Pin 9 on the seat switch connector is where the switch received +12V. The other eight wires on the connector route the +12V from the seat switch to the seat controller module. These are the cushion up/down, seat back tilt fwd/back, seat fwd/back, and lumbar in/out. Doesn't matter what generation the seat switch comes from. It's up to the controller module (or wiring) that simultaneously sends voltage and ground to the 2-wires on the seat motor.
How to make it work
You sound pretty handy. Here is something for you to consider. I pulled the seat. Two connectors. One has 2 wires - per and ground. Other is everything else. With seat out leaning upside down on chair, removed clips on two small shafts that hold up/down motor. Pulled small 5- wire connector. With motor on bench, used small 12v battery from lawnmower. learned two thicker wires to motor are the answer. When connected +/- motor turns cw. When battery reversed turns ccw. So if you get a double throw switch from radio shack or other, just directly wire + and - to motor and switch. That will bypass everything else and raise/ lower seat bottom
