Power Steering hose leak
After extensive leak hunting I managed to eliminate all leaks and replace all major hoses and delicate parts from the cooling system, and I also replaced the valve cover gaskets again (this time I dabbed some RTV to correct that mistake from when I changed the tensioners).
I parked my car in the garage and checked a few hours later to see if there were any leaks. Lo and behold only one leak left. Upon inspection it was red in colour, so I thought to myself, that is definitely ATF, which means power steering.
This is what I found above the leak:
![Power Steering hose leak-image.jpeg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/125149d1454810634t-power-steering-hose-leak-image.jpeg)
It seems this hose is leaking at the connectors, which tells me the o-rings are shot. I was thinking about removing the hose and having a new one made at a hydraulic hose shop. This is the driver's side hose; I already fixed a similar leak in the passenger side under the airbox by cutting the hose, yanking out the connector, slipping in a new hose with clamps. I would like to avoid that kind of trouble this time around.
How do I go about removing it? This hose seems less accessible than the one under the airbox. Is there a specific quick disconnect tool I can use? How do I remove the connectors and fix or replace those? I don't want to mend it the same way I did the other hose.
Have you thought about using a product like Lubeguard? I think thats what its called. I used it in my XKR not because it had a leak just to get rid of any annoying sound that occasionally appeared. Its good stuff. Just look it up on Amazon etc and read the reviews.
I dont have any connection with the product. Just as a user.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Lubegard 20404 Universal Power Steering Fluid Protectant, I think its leak cure too?
Here you go, save you looking it up.
I know its a UK site and you guys all drive on the wrong side of the road but it should work just as well for you.
Lubegard 20404 Universal Power Steering Fluid Protectant, 4 oz.: Amazon.co.uk: Car & Motorbike
giandanielxk8 (02-07-2016)
Alright, I'll get some of the lubeguard.
I cleaned up the area and identified my leak; its the hose that goes from the reservoir to the pump.
So, the hose itself costs $20 from RockAuto. Its the low pressure hose MJA390AD according to my parts catalogue.
Can an off the shelf hose from Pep Boys be used instead? As long as the diameter and length is appropriate it'll work. The hose doesn't seem to have any complicated bends.
Lagonia
19
04-18-2021 02:19 PM
jagnew
07-22-2017 07:45 AM
Lisa Lou
General Tech Help
01-23-2016 03:24 PM
mophoto
01-14-2016 07:42 PM
