power steering hoses
I recently replaced the suction hose from the reservoir to
the pump, in the process the smaller hose that is also
connected to the reservoir developed a leak, the hose is so
dry that it would crack when I would push it over the ******
connector. I have ordered the hose which includes the
cooler. It connects to the ****** end with a plain end. The
other end utilizes a push on quick connect type fitting that
utilizes O rings for the seal. I cannot find any post or
online posting that indicates the type or size of tool
needed to remove this quick connect fitting. I have read
that it is a fuel line connection tool, but I have found no
verification of this. Does anyone know what that tool size
is or if it is specific to jaguar. Any help in this matter
would be greatly appreciated.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Go to Autozone or any auto parts store and pick up a set of the Fuel Line Disconnect tools for about $10.00 which has various sizes and you can find the one that works.Here is a link to a set at Sears;
http://www.sears.com/shc/s/p_10153_1...4255000P?mv=rr
Good luck!
Good luck!
This is how I did my repair! You do not need the cooler tube just buy the hose and some 3/8" to 5/8" breeze clamps.
https://www.jaguarforums.com/forum/a...p?albumid=1282
You can also read my entire post and process.
https://www.jaguarforums.com/forum/s...g+line+leaking
This will save you M O N E Y !!!!!!!!!!!!
clubairth1
29
05-10-2024 12:57 PM
Dicque
09-19-2015 12:53 PM
1964Daimler
09-09-2015 11:28 AM
