Power Steering Leak
I've had a small oil leak for the short time I've owned my 1998 XK8, and I've had to add Power Steering Fluid.
I got under the car today to check out where the leak is, and it appears that the pressure hose coming from the bottom of the P/S pump and going to the rack is leaking. It's a foam covered hose and the foam is worn in one spot and saturated with fluid.
Has anyone had the pleasure of replacing this hose?
It looks like nasty job, so I was hoping for some suggestions to make the job easier (if that is possible)
Thanks,
Dave B.
Thanks,
Dave B.
rusty37
04-05-2020 07:40 PM
Dicque
09-19-2015 12:53 PM
