power steering leak
The lousy plastic connector that joins the metal tube portion of the power steering line to the rubber hose portion of the power steering line is the usual suspect. It is located next to the alternator on the outbound side. You will need to remove the airbox to get to it. A common fix is cutting off the plastic connector and installing a brass hose barb along with a bit of new rubber hose to permanently solve the problem....
sunchip
01-28-2015 08:21 AM
MarcB
01-16-2012 10:29 AM
ccajun4real
11-08-2008 07:41 AM
