Power steering leak, common problem?
Search the forum for this...if it is leaking on the passenger side (US models) under the air filter box area, there is an inexpensive, do it yourself, reliable fix. I'm going on 2 years with zero leaks since I fixed mine. It involves cutting the fitting end off and using a barbed brass fitting in the hose end and a short rubber hose to the brass fitting and the other end of that sliding over the cut tube with clamps. There are photos and a write up on the forum somewhere.
