Powerflex front end
Powerflex front end
Just as a note to anyone considering fitting poly bushes.
I have just renewed all of my front suspension bushes, it's the first time I've stripped the xk but it all went well.
I started on the RH side, it took a total of 5 hrs to strip it, change the bushes and refit it all. The top wishbone is pretty easy, the lower is a bit of a pig and the damper was a complete B.
The LH side took 3 hrs (I knew what I was doing by this point)
The result is a very quiet front end, all the little knocks and rattles have gone and the car feels far more positive.
It was very much worth the money and the effort, if your considering it I would say do it, you'll need a press to do the damper lower joints, and a little patience to get the boots and clips back on again.
I just had my XJR front end redone. Didn't do it but the result is simply transforming. The car drives so much nicer. A little more road vibration comes thru the wheel esp. on nasty roads but the positive feeling is so much worth it. Having used poly for years, I've never had an issue with noise as tberg has. It makes me wonder if something wasn't done properly. My TVR doesn't have a single rubber bushing on the car at this point and no noise out of the bushes.
I'm hoping to do the XK over the winter myself. Glad someone has had some good results with doing it on ther XK. I'll be the first to admit that it isn't for everyone, but I am a believer.
For the past couple of weeks, my front suspension has been squeaking and making so much noise that it's almost unbearable to drive. It's going in on Friday as my mechanic who listened to it yesterday thinks it's the poly busings in need of grease. I can't believe that much noise could come out of bushings alone. But, we'll see. While the ride as well as the car's ability to take dips and bumps improved, the noise caused by the poly bushings is simply unacceptable, and I'll most likely replace them with OEM rubber bushings. I'll report back on Monday as to the findings and the solutions. It's just terrible right now.
Were there any particular issues with the lower bushes? I need to do mine over the next couple of weeks, the tops having been done last year - apparently they were not easy as the bolt had seized, fortunately I had those done at the local garage but plan on doing the lower ones myself. Any advice for doing the wishbone bushes only with the Powerflex bushes?
One could drill passageways for lubrication and install service fittings (grease zerks) to accommodate poly bushings but that would negate the ease-of-install advantage. Personally, I don't care much for poly bushings but understand the initial advantage during installation. About the only areas I'll consider using them is anti-roll bar links, suspension strut rods and some mounts as they are then only subjected to flexing, not rotating forces.
Just my $0.02 worth...
Plenty of silicone spray to get the wishbone back on and your away.
I'd estimate 3-4 hours for the first one and less than 2 for the second.
Good luck, let me know how you get on
andyps (07-05-2013)
I've been sitting back, waiting for peeps to begin complaining about their poly bushings. There's a case to be made for them - they're slightly easier for DIYers to install. And in the case of large bushings they are a bit less compliant, possibly yielding more positive handling and road feel at the expense of smoother ride. But that's where it all ends. Poly bushings do require periodic lubrication, unlike torsilastic bushings. Poly bushings rotate, inside and out, as the suspension flexes. Torsilastic bushings merely flex and friction is not a concern.
I have had Powerflex lower control arm bushings on my XKR car since 2008 and have logged over 70K miles since (including 4 years in the desert Southwest) and I have zero issues and no noise whatsoever. FYI I had to replace the stock bushings twice @ roughly 20K and 40K miles so that was my impetus. Great decision.
Beav,
You're absolutely right. I have poly bushings on both my XKR and my Pantera, and they both make a lot of noise. Now, I've probably put 50,000+ miles on the XKR since the original bushings were replaced, and the squeaking began only a couple of weeks ago, however, they always "moan and groan" going over even the smallest of dips or bumps. I was told a long time ago by a car restorer not to use the poly bushings; I should have listened.
I got my car back this afternoon, and the cacaphony that sounded like a flock of parrots coming from the front end is mercifully gone. My mechanic said they spent seven hours removing, greasing, and replacing all of the poly bushings. Honestly, I can't believe it, the noise was so pervasive, I could not fathom that lubrication alone could make the difference. I am delighted but will not use the poly bushings again.
aholbro1
08-05-2021 05:02 AM
