Powerfold Mirrors - fuse or relay?
I don't use the Powerfold function and haven't done so since checking it worked when I bought the car last November. However, after Powerfold was mentioned in a thread recently, I thought I'd check it after washing the car this morning.
Nothing.
Just a click from somewhere under the LH side of the dash. You never miss something until it's gone!
The normal adjust and reverse dip functions both work. The mirrors are definitely properly engaged on the drive pegs and I am trying it with the switch in the centre position.
The Handbook doesn't show a separate fuse or relay for Powerfold. Is there one or the other inside the door casing?
Nothing.
![Roll Eyes (Sarcastic)](https://www.jaguarforums.com/forum/images/smilies/rolleyes.gif)
had the same problem..when you drive in the rain with your window down or open your window after its been raining sod law says water will fall on the switch assembly ...took mine aparts and it was green from water ingres ..had to buy a new one..got it from stratstones and it cost me £99..take it apart and see all the little copper pieces and springs fly all over the place..hope this helps
Another check to add to the list - thanks.
![Icon Screwy](https://www.jaguarforums.com/forum/images/smilies/icon_screwy.gif)
GGG (08-12-2012)
I'd better have both Seat Modules out to check for breaks and the Driver's Door card off to check the switch.
Thanks for checking the drawing.
gunlocators
09-30-2015 08:05 AM
