Pre-heat oil using electric block heater
Maybe the pickup screen was gummed up and having the oil warm at startup helped the oil suspend the varnish. Now it flows better at all times.
If that is the case, maybe a couple of warmups like that before each oil change could be helpful.
In the meantime, it seems there is a in pan oil heater available. It is a straight heating element mounted on a 1/2 NPT bush that goes through the side of the oil pan. The cord attaches to the outside of the bush. You would have to remove and drill the oil pan. Search temro + oil on ebay ... about $35.
The API measurement of operating temp viscosity is at 100*C, the HTHS at 150*C, and the typical flash point of conventional engine oil is over 200*C.
The oil heaters are not meant to get the oil even to operating temperature, only to get it warm enough to be usefully close to operating temperature rather than being a jelly.
Received 2,263 Likes
True that, and today's 0W and 5W grade oils (as recommended in the owners manual) really don't need external help in staying thin enough for starting.
As why the OP's problem went away, I seriously doubt it had anything to do with the temporary addition of a heater. Applying 300 watts of heat to bottom of a V8 engine for one hour will make little appreciable difference in heating the oil. The heat is radiating to atmosphere almost as fast as it is being created.
Most block heaters up here are 800-900 watts and are used only when it actually gets cold, -20*C or less. My S-type came with a factory installed example, I never bother with it.
guy (09-11-2013)
Besides the block heater, I have also installed a 250 watt heater like below on the engine and gearbox oil pan:
Amazon.com: Wolverine Engine Oil and Hydraulic Fluid Heater. Commercial Quality. Model 16 - 250 Watts, available in 120 or 240 Volts. For Oil Capacities of 5-13 U.S. Qts. (5 - 12 Liters) and Hydraulic Fluid 10 to 30 gallons, (38 to 114 liters): Autom
Works very well.
![Amazon.com: Wolverine Engine Oil and Hydraulic Fluid Heater. Commercial Quality. Model 16 - 250 Watts, available in 120 or 240 Volts. For Oil Capacities of 5-13 U.S. Qts. (5 - 12 Liters) and Hydraulic Fluid 10 to 30 gallons, (38 to 114 liters): Autom](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
Works very well.
#31
![Thumbs down](https://www.jaguarforums.com/forum/images/icons/icon13.gif)
The Hawthorne effect (commonly referred to as the observer effect) is a form of reactivity whereby subjects improve or modify an aspect of their behavior, which is being experimentally measured, in response to the fact that they know that they are being studied,[1][2] not in response to any particular experimental manipulation.
Both oil and ferrous particles are inanimate, unsentient objects.
Now if you are trying to state that engine oil and gear oil do not have an optimal operating temperature range that is above ambient, I suggest you do some reading of the technical literature, not internet "experts" ... or go post your claim at bobistheoilguy.com ... make sure you post it as an assertion of obvious fact .. they'll have a field day with you.
If that doesn't work at bobistheoilguy, you can always fall back to the position that oil and contaminants thereof are in fact animate, sentient beings subject to "The Hawthorne Effect".
LOL x 2
#33
#34
