pressure test cooling sy
Reservoir
The consensus indicates that Harbor Freight has the best pressure testing kit for compatibility with Jaguars.
Have a read through this: https://www.jaguarforums.com/forum/x...adaptor-78352/
I have never used one myself as I've been lucky and been able to visually spot the leaks.
Cheers,
Stu
Cheers,
Stu
Received 2,400 Likes
This is what I did to pressure test one of our XJ8’s recently. I have not tried it on the XK8 but I would imagine it would work the same. Instead of buying a pressure test kit I would only use every once in a great while, I instead took a few minutes and rigged up a simple hose and schrader valve that I could attach a bicycle pump to, and it worked like a charm. Here is the link:
https://www.jaguarforums.com/forum/x...-cheap-196041/
StuG (04-04-2018)
Johnken
07-12-2016 08:08 AM
car5car
02-10-2016 04:58 AM
GordoCatCar
07-28-2015 06:07 AM
