Pretty sure this is my fuel pump, but ????
This list should help you with the fuse and relay locations
Link http://jagrepair.com/images/Electric...eLocations.pdf
This link is the wiring diagram for your car
Link http://jagrepair.com/images/AutoRepa.../jagxk2000.pdf
Fuel trim info
Link http://jagrepair.com/UsingFuelTrims.htm
Fuel trim info
You can get to the O2 from the top but not easy. I used a duel open end wrench and used a box end wrench on the other end of the open end for leverage. As for the plug it is usually up top on that side just follow the lead and you will find it. If for any reason you are unable to get it loose and you need to drop the cat I would recommend that you spray the nuts on top with PB Blaster and let it soak for about an hour. They are not easy to get loose. Also if you drop the cat get a new gasket for it or you may have an exhaust leak and you will need to drop it again. Check your PM.
