Problem filling up
Guest
Posts: n/a
Problem filling up
No, not the price, although that continues to be a shock. The gas won't flow! Can only add about 4 - 6 ounces, then backs up. It will slowly trickle down, about 5 seconds, then I can add another similar amount. This was very sudden, last fillup was fine, not sluggish at all. Is there a filter between the filler and the tank? Could it have suddenly become clogged?
Bart Kinlein
Bart Kinlein
RE: Problem filling up
A few months back we had a check engine light which turned out to be a problem with the evap canister valve, it was stuck open because of debris from the vapor pipe. The dealer said it could have also caused the problem your having. Have the canister control valve (CCV) checked.
