Problems pairing garage door opener
Old 08-06-2021, 07:23 AM
brobin's Avatar
Glad to hear it! Just had to the same for my friend at his new home for his 99 XK8.
Old 04-02-2022, 07:51 PM
paulnelson's Avatar
Banned
I followed the instruction and tried to pair the garage door opener with the optional device under my rearview reflector. Even I reached the point of fast blinking step, it won't open my garage door repair Chesapeake VA
And when I push the button B, e.g. alone, it blinks like crazy but the garage door has no response at all. Any suggestions/recommendations?? Thanks in advance.
Old 04-03-2022, 09:48 AM
brobin's Avatar
Did you pair the device itself with the opener first? It sounds like you paired the car to the remote OK so maybe the device isn't paired to to opener.
Old 04-03-2022, 11:10 AM
bcprice36's Avatar
RandyB....
Looks like you have done just about everything a Man can do! When I moved in here at the Ranch (1993) it was simple to program the Door, but somewhere around 2015, I had to have it replaced with a "Chamberlian" system! Of course the Garage Door Guy left the programing to me! I fooled with it for about a week and finally called the Company and discovered that there is a "Button" on the side of the System, Yes! it's up there....get a ladder....that you have to push it before it will start working!
I know....."READ THE DIRECTIONS"
Billy Clyde @ Cinco Ranch
Old 09-03-2022, 07:58 AM
99 XJ VDP SC's Avatar
I have a 99 and a garage door opener with rolling codes. My number 1 button is missing so I couldn't clear all codes. But I kept after this and after several fails I got the number three button opening my garage. So don't give up because tossing that remote is satisfying!
One thing to note is I have to hold the 3 button down for about a second to get the door to open. So you might have to hold it down for two seconds to be sure it's programming, too. Just remember, because of the rolling codes, you have to pair the remote to the console and then also climb a ladder to pair the garage door opener to the console several times. Good luck!
Last edited by 99 XJ VDP SC; 09-03-2022 at 08:03 AM. Reason: Expanded on my post below this one. So this one is duplicate.
Old 09-03-2022, 08:00 AM
Also, if it matters to anybody, I was using a Crafstman three button universal remote before I succeeded and threw it in a drawer.
Jbm417
10-14-2021 09:01 AM
xk8newbie
02-03-2017 10:20 PM
Brian XK8
07-06-2016 06:36 AM
dennyhle
01-28-2016 11:57 AM
Blacksunshine1972
11-02-2014 05:30 AM
Quick Reply: Problems pairing garage door opener
