Programming key FOB
Thanks guys for the responses. I'll have her come by my shop to see if I can program it for her instead of trying it over the phone. My confusion is that if you put the car in valet mode doesn't that make it so the transmitter won't to open the trunk, or even the lock doors I don't know, so how is the transmitter reactivated. If it's just by pressing the valet button that makes the button worthless because the valet can push the button and have access to your trunk. I would think you would need a regular key to deactivate the valet mode to make the transmitter work again. I might be over thinking this if I am please correct me.
Valet question: my valet on mode is disabled by using remote. 1998 xk8 hope that helps.
Your question is logical, I guess you have to hand the valet only the green key and expect them to lock the car using the driver door keyhole, which will turn alarm on. As I recall the glove box will Only open with the black Keys key (just thinking out loud)
Fwiw I do know the trunk open switch is disabled with alarm armed.
If you need a key to open the boot, it's pretty straightforward to convert the valet key to a normal key - you just need to file a small amount off the shoulders at the end of the key.
Have a look at these threads:
https://www.jaguarforums.com/forum/x...ing-xk8-80490/
https://www.jaguarforums.com/forum/x...lar-key-85170/
Hey Johnken, I don't think the movie should be My Cousin Vinny but a James Bond movie,preferably with Sean Connery. His having to retrieve some important documents from the boot of a Jaguar parked at a restaurant and all he had was the valet key and a file. After all these are British vehicles.
Johnken (05-31-2016)
The VALET MODE is canceled by activating the boot light. If the micro-switch or wiring is faulty, then the VALET MODE will not cancel.
You don't need a keyfob transmitter, just open the boot lid, but what kind of Jag owner only has a VALET KEY????? That does not seem like a bright idea to me.
Whenever a customer comes into my shop I usually ask if that is the only key they have? If the answer is Yes, I shake my head and remind them what kind of trouble they are asking for.
They usually call back in 6 months whining about how the key is lost and "OH what am I going to do now?" In my head I'm thinking "SUCKS TO BE YOU!!!!"
bob
bob
She just bought the car and is taking care of things one at a time. She has a key fob and ask me about programming it. And I was posting to see if it was possible to program it with only the valet key. One of the xj8s I bought the guys girlfriend had lost the key. He had a blank key and I thought no problem i'll get the key cut and be on my way. This was before I knew about the programming of the key. I took it to the local Jaguar dealer had them cut the blank key and bought a spare. After about an hour the tech said they couldn't get the modules or something to work so he couldn't program the keys. This cost me over $300 dollars for a car I bought for $ 700. I decided that I wasn't going to keep throwing money at it to get it going. Now it's my donor car which it has paid for itself. Now if I look at a car if they don't have at least one regular key I walk away.
