Protective tape in the gear selector
Hi
As i'm sure your all aware Jaguar put a strip of protective soft finish in the J gate that stops the gear stick/ selector from rubbing metal on metal.
Mine has started to come away on the right between Park & Drive.
I wondered if anyone else had already found a solution?
regards
regards
The other 61 Viewers so far are saying nothing but I'll admit I wasn't aware!
Haven't got an XK8 any longer to be able to check but is this the Illumination Module Gasket? If so, it's not illustrated in the Parts Catalogue but there is a P/N for it:
![Protective tape in the gear selector-xk8-transmission-selector.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/75344d1480971592t-protective-tape-gear-selector-xk8-transmission-selector.jpg)
The following 3 users liked this post by motorcarman:
then i'll have to go with engineer because the battery is in the trunk,
and the fender covers happen as #3 after battery disconnect as #2
all good fodder for the cannon when it is claimed here that Jaguar engineers could not possibly be wrong and are as infallabile as a religious deity.
3. Open the hood and place covers over the fenders.
This TSB is exactly what I needed thanks. While im in there i'll replace a failed back lighting lamp.
Also isn't my model year shown on my signature? If not i'll do it again.
thanks
mike66 (03-14-2014)
