Pulsating Pedal & front end shimmy
Just started up the cat for the first time in 6 months, after a battery charge. She sat in the driveway all winter and still had 32psi in all four paws. Started up first try with old gas in the tank a she immediately started purring like contented kitty.
However, she did not want to move after selecting R. Felt like the wheels were rusted and locked up. It took a little gas to free them up.
Now the issue, when apply brakes, pedal felt mushy, brake pedal pulsated and front end had a shimmy under braking. Drove for about 30 minutes. Brake pedal seemed to firm up a bit but the shimmy and pulsating never went away. It feels like a warped rotor in the brake pedal but the rotors were fine when I parked it last November. There is no pull to the left or right under braking. If some of the calipers are sticking, could it result in the symptoms I am having. Any suggestions would be appreciated. Thanks, Tim
The result was moderate to severe pulsations when braking.
The techs referred to it as "Lot Rot".
The rotors had to be turned on a Lathe to remove the Rust.
Paul and WhiteXKR,
thanks for the replies. I am guilty of the lot rot for sure. Will try some more aggressive braking to see if I can scrape off the crud. I did try this to a limited degree but backed off due to the extent of the front end shake. I was worried the shaking going on might break something else.
Do you think I might have any luck using steel wool and some rust remover on the rotors?
thanks, Tim
thanks, Tim
Paul and WhiteXKR,
thanks, Tim
thanks, Tim
When I had my '03 XK8 inspected by a Jag dealer shop before I purchased the car, I was told that Jaguar does NOT recommend machining the brake rotors at any time... I am sure my eyebrows went up a bit. Sounds like a good way to make more money. Any comments on that? Proper machining of brake rotors has always helped extend the life of rotors on my other cars.
Received 2,260 Likes
aholbro1
08-05-2021 05:02 AM
hen555
09-07-2015 11:13 PM
