Quarter window stops too soon.
A couple of days ago my right rear quarter window stopped closing all the way. Its smooth going up and down, it just stops about 1 second before the left window does and of course leaves a 1/4 in opening between the front and rear glass. I tried to "help" it up and it still just stops in the same place. It acts like a programing issue like the front windows, but so far I havent figured out the sequence. anybody got any ideas?
Bob
Bob
Bob you might get better responses by putting the model into the title.
A vague idea at best; window memory module out of kilter. With windows closed as best as possible. From inside the car start with drivers window. Wind fully down and hold switch for approx 4 seconds. then wind fully up and hold switch for approx 8 seconds.
You now need to be a bit athletic because you need to repeat this procedure for each window using its own individual door switch. Do not open a door. Do not use Driver master switch. Only use individual window switches.
Thats the best I can give you, hope someone who knows more can help.
aholbro1
08-05-2021 05:02 AM
kabs3012
09-12-2015 10:40 AM
