Question about ECU swap for 4.2
My friend's ECU on his 2005 4.2 XK8 is shot. I tried to communicate with it using IDS, to no avail. I have a genuine ford VCM and it communicates with my 2000 XK8 and 1996 XJR just fine. The original ECU for the car was mailed to a rebuilder and lost. This is a used replacement ECU that I suspect is not good. I would like to buy an ECU from another 4.2 XK8 and swap. Here are my questions:
1. Are 2005 and 2005 ECUs interchangeable? I am assuming that the ECUs from 4.0 are not.
2. What other modules are "married" to the ECU, if any? I.e. do I need to also swap some immobilizer-related modules?
3. What kind of reprogramming via IDA (if any) will be needed for the ECU swap?
Thanks in advance.
Thanks in advance.
Received 2,381 Likes
The following 3 users liked this post by motorcarman:
The following 4 users liked this post by motorcarman:
The original ECU has the following numbers:
MB089700-9490
12V SPAIN
DENSO
04200401090000800797009490
JAGUAR 4W83-10K975-CA
*009490* X100 4.2L NA
CA
The proposed replacement ECU has the following numbers:
MB089700-9113
12V SPAIN
DENSO
0120020830000003079709113
JAGUAR 3W83-10K975-AD
*009113* X100 4.2L NA
AD
I don't see any numbers that start with c2n anywhere. Any pointers how to understand what is on the ECU labels would be appreciated.
I have IDS and SDD on my laptop, and a genuine Ford VCM. Can it be used for programming the ECU to the car? I am not familiar with SDD, what hardware is needed for it?
MB089700-9490
12V SPAIN
DENSO
CA
MB089700-9113
12V SPAIN
DENSO
AD
What is the part # printed on the car's VCATS label? That would help to narrow it down.
If the car is 2005, I'd expect C2N3338.
IDK how you would translate the codes other than, possibly, searching.
There are quite a few hits for both of the xW83 prefixes.
I *think* your replacement is from a 2003 car.
Hi,
I've just done a search re the VCATS label and found another owner of a 2004 who couldn't find it either, so Jaguar has presumably moved it or it's just not present on the 4.2?
I would not change any modules at this stage as you would be introducing other variables.
The earlier ECM may be OK, or there may be things that don't work. Bob (motorcarman) is the module guru on here:- perhaps send him a PM if he doesn't drop by again. He will be better placed to guide you.
i’ve told you how to do a quick and dirty swap to get it running without risking anything.
just enter immobilization setup follow the instructions and the car will start with the donor’s ecu. later on you can reprogram it and rebuild the original VID block from the as-built database in IDS.
VCATS labels are only found on the X100 not the X103
The following 3 users liked this post by xalty:
I worked out fine. He bought a used ECU for short money and I used IDS to program immobilizer so that the car would start. It took about an hour of messing around to find the right menu in the IDS. I had to use the VIN of the ECU donor car, not the actual VIN of the car.
