Question about hiring a press
I hate asking what is probably obvious, but you've helped me through more obvious ones so here goes.
I am preparing to start my front bearing replacement job. I asked the auto parts store how much it would cost to press the bearings out since I bought the part there. They said $40 per press.
It wasn't until I got home and thought about the job, when I realized this isn't as simple as it appears.
For a bearing replacement, think of all the pressing needed:
1) Hub removal
2)Old bearing out
circlip 1 installed (more on that in a moment)
3)New bearing in
circlip 2
4) Hub pressed in
Guys, am I reasonable to expect all 4 presses to be in a $40 charge? If no, wow I was trying to save money doing it myself. Hiring the mechanic would have been cheaper!
Question2:
The Jaguar workshop manual is clear on 2 items. 1)Install the circlips with gap facing down to allow water to drain.
2)Do not use a circlip removal tool that has a pin which protrudes past the thickness of the circlip. A scratch may comprise the bearings seal.
Looks like the first circlip must be installed before bearing is pressed in. Maybe this serves as a locating stop for bearing being pressed in?
I can't very well expect the auto parts store to stagger and synch their work with me so I can run over and install the circlips in the proper orientation a
in between the bearing press and the hub press.
Am I reasonable to expect them to manage the circlips properly under that same $40 price?
The first time you do something like this it probably seems a lot more complicated than need be, but I'm trying to set this up to go smoothly.
I appreciate your advice and experience.
John
1) Hub removal
2)Old bearing out
3)New bearing in
circlip 2
4) Hub pressed in
Question2:
John
I bought a Harbor Freight 20 ton press to do mine mostly because I wasn't willing to trust the typical shop and figured a specialist would charge more than the cost of the press. But I have a project coming up that will make considerable use of it to further justify the purchase.
While it's possible to replace the bearings without special adapters I was able to have a friend turn the support from bar stock for the final assembly, and that made it easier. Large sockets sufficed for pressing out the old bearings.
Johnken (08-11-2017)
Ron
Steve,
Thanks. Looks like it's gonna be a trip to harbor freight. Bet it feels 10x better to do entire job yourself.
From what you recall, is new circlip #1 inserted before new bearing to serve as a stop for the press ?
I imagine it is a guide as to when to stop pressing, but I could be wrong.
John
John
Steve,
John
John
+1 to all on the HF 20T press. After once paying $50 for a shop to warp my (Honda) hub, which in time I did over, the cost was justified along with the satisfaction of knowing what I have done. (Also, FWIW, I remove the outrigger angles and hang my press out of the way, flush against my garage wall)
https://t.harborfreight.com/10-piece...set-63261.html
This and this;
\https://t.harborfreight.com/6-ton-a-...ress-1666.html
Or
https://t.harborfreight.com/12-ton-s...ess-33497.html
Would be sufficient for the job and then you are set for doing other things that might (read will) crop up.
This and this;
Or
Johnken (08-12-2017)
Johnken (08-13-2017)
